hi i need a bit of help how far does your nose cone sit off the front of your chassis and how far from the top of your chassis to the top of the nose
cone.
adam
Is that a D*CK?
No, you're a D*CK
You need a radiator gap in there. I've modified a nosecone I bought and made it taller and it's evolved gradually
into something like I originally intended. I made the top rounder and the front deeper and it now fits easily round the Micra radiator in there. From
the chassis to the bit where the grill sits is 280mm and the top of the arch where the bonnet sits is 200mm.
