can someone tell me the height of the chassis rails on an mk indy, cheers
Its variable, so I am not sure what you mean.
Steve.
where the scuttle sits, from the bottom of the bottom rail to the top of th top rail.
I have measured from the bottom of the chassis rail to the top of the chassis rail in the engine bay as near as possible to the scuttle and it is
35cm.
Steve.
ok great, is it the same heigh from there back to the scuttle, i believe from the scuttle back it drops, so i assume the chassis rails are parallel from the front to the back of thescuttle?
If nobody else responds i will have a look in the morning, bed time now.
many thanks steve, much appreciated
It is a bit tricky to check but it very much looks like the top and bottom chassis rails are parralell from the front of the scuttle along to the
bottom edge of the dash, then they start to close towards the rear.
Steve.
i was under the impression the indy had 14" sides to fit a pinto, whereas a locost has 13" sides.
the side rails are parallel from the front to the back of the scuttle where they drop towards the back arch.
tom
ok thanks guys,
