I've seen a few posts mentioning torque spreadsheets for tightening bolts based on the bolt size and type. But doing a search isn't bringing
anything back apart from a few references to Haynes manuals for the donors. Does anyone have an up to date link (or spreadsheet) for torque
settings?
And lastly, can I also confirm that it doesn't matter whether the nut is nyloc or not, it's still tightened to the same torque?
Look here:
http://www.roymech.co.uk/Useful_Tables/Screws/Screw_loads.htm
Awesome, thanks! Is it ok to use the maximum torque value, or is it better to stay below it, say 90%?
I think it would be wise to reduce the figures by the 10% as you suggest.
Excellent, it's really appreciated.
A lock nut will make a difference as it will increase the friction "felt" by the torque wrench
