I wonder if I could get some opinions on these items and whether they're well priced?
First, a full set of bushes and crush tubes;
HAYNES ROADSTER LOCOST EYELET BUSHES X 22 - STAINLESS INSERTS AS PER BOOK | eBay
Works out to be about £2.50 a piece? Although I might go rose joints instead.
Next, suspension brackets;
34mm Haynes Roadster Locost shock absorber brackets | eBay
Obviously expensive compared to metal plate cut and drilled, but for a pre-made piece it seems ok?
Last item is a pack of hacksaw blades;
BAHCO SANDFLEX 24TPI 12"' BI-METAL HACKSAW BLADES x 10 PACK OF 10 METAL CUTTING | eBay
I'm currently using a Bahco blade and it's a world of difference to the blades I've used before, but is £11 for a 10 pack good?
Next, suspension brackets; 34mm Haynes Roadster Locost shock absorber brackets | eBay![]()
Suspension bushes, you've answered your own question
Cheap enough
Brackets it's the postage that bothers me, you could ask for a bulk postage price as that's what costs the most per item
Cheap enough
The brackets are from Dave near donny. He did all mine. He will post stuff together cheaper if you need a lot.
They are very well priced.
He also can make any size. Like for my tiger etc.....
He also has Cnc cut parts like the wishbone bits..
Posted me 10 for about £12
[Edited on 24/2/13 by jossey]
They are the shock brackets... you only need 4 as they are narrower than the suspension brackets on the haynes
