Im still building my little special, and, because it is so little packaging of the rear suspension is being somewhat challenging, I need to locate
the rear suspension a bit better than the 1/4 eliptics offer.
Ideally I would put a watts linkage thru the centerline of the dif, but the fuel tank sits far to close to the axle to allow the link to fit, nor is
there space for a panhard link to work effectively without causing body jack. so, my thoughts have gone back to the watts linkage, but mounting it in
a different plain, If I mount the pivot pin on the bottom of the diff, and mount the rocker arm in a spherical bearing, so making the watts link run
under the diff, obviously all will fit within the scrub radius, and only protruding perhaps 30mm lower than the diff casing, I dont see this causing
any problems, and, might if im thinking correctly probably lowers the roll centre too?
I think I follow your description, but a sketch if you can may help others understand it and comment on it.
Do you mean something like this;
Obviously my brain is not as addled a I suspected
Yup, that's exactly what I meant and really helps illustrate what you have in mind.
Having something lower than the bottom of the diff runs a risk of being bashed, but TBH if you bash something like that you're likely to be off
road in it.
There is another linkage which some say is far superior to Watts, its called the Mumford set up, I have drawings and pictures but cant fathom how to upload yet. I use it on my Dutton and it seems OK but have nothing to compare it with.
The Mumford link was used on U2 Clubmans cars if I recall, supposedly to lower the roll centre compared with a conventional Watts linkage. I suspect it would have the same package problems as the latter have for you.
Ive seen the Mumford link before, certainly wont work on my application, another axle control is using a 2" ball race mounted on the back of the diff in line with the pinion, as per watts link, this bearing runs in a vertical track/channel mounted from the chassis on the centerline of the car, The axle is FIXED along its centreline, can rise up and down and pivot about the pinion axis, total control as the expense of being high maintenance and NOISIER than a noisy thing
I've never seen that written up before, interesting. Would like to see that ball race idea, I to have space problems temporarily fixed with a ball piened hammer on the fuel tank flange.
Would like to see that ball race idea...
thanks for that, interesting.
It used to be quite a common solution with 1950's de Dion axled race cars. Some quite famous cars like the Mercedes Benz W125, BRM V16, Maserati 250F, Aston Martin DBR2 and Lister Jaguar used it. It's usually called 'sliding block' location. This is the Lister Jag (diagram from Costin and Phipps):
As Ian said, the dual problems were maintenance (wear) and noise. Even the slightest bit of play in the slide block would make it bang and clonk like hell. Possibly you could improve it these days, by using DU bushes sliding on a hardened steel rod (as in a damper) and isolated by mounting them in a metalastic or polybush, but it's a lot of trouble to go to for a suspension system that's never going to be as good as a properly designed IRS.
The other problem is that you can have geometry conflicts with other links: for instance if your sliding block wants to travel up and down in a perfectly straight line, but your trailing arms want to make it move in an arc.
Yes, absolutely - there are ways around it (another is to use a form of longitudinal location that doesn't move through conflicting arcs, such as the wishbone arrangement on the Veritas), but it's always added complication that is difficult to justify when it gets to the point that a well-designed IRS is both technically superior and cheaper.
