Does anyone have any photos of the mac#1 chassis? As bare as possible would be nice so I can see it clearly.
Thanks,
Pete
Same as MK Indy, but without the bent tubes.
Was jigged from an Indy. All the suspension is interchangable.
Kind regards,
Darren
Does it have any extra bracing in the engine bay?
Pete
I seem to remember the engine cradle is mounted slightly different but essentially the same although the tunnel is higher.
Give the guys a ring there I am sure they will happily send you some pics, great guys and always very helpful and really good to chat to.
Rich.
Just like to add that GTS front suspension is also interchangable. So you can get cool adjustable top wishbones made in flat oval for your Mach and MK from www.gtstuning.co.uk
