i wanted to change the hub carriers- (i think thats what their called- the bit the alloys attaches onto) from the normal sierra ones to 5 stud ones (ive seen some nice 5 stud alloys on ebay). how hard it this to do, and would i be able to change them back if i wanted to? help would be appreciated!!!
would that work for disks do you know?
would be similar
but im guessing instead of remove drum
remove calipers, carriers, pads discs etc
and undoing the hub nut will be fun (from memory i cant remember if the hub nut is underneath the disc
Originally posted by natehall
would be similar
I would be interested to know how you make out on this swap. Our Merkur XR4ti is the 4 bolt and the scorpio is the 5 bolt. I too thought they were
interchangeable, so got one of each.
Turns out that they are different designs altogether. The 4-bolt has the bearings nounted on the lobro shaft part and the 5 bolt has the bearings
mounted on the whell hub half. Maybe different for the Sierra family
