Hi All,
Chassis Plate on FleaBay
I just stumbled across this on FleaBay. Anyone got one? What do you think about it, will it be suitable for SVA?
O
wouldnt bother your local cobbler will do you a plate for about 6 quid
I got one, it came quickly and is well made. It will do for one of the chassis number markings but you still need one on the chassis itself that is
non removeable so stamped or engraved into it
Caber
Probably OK from a point of view of showing the VIN (and engine no.) but the SVA man might not like the fact that it says "Lotus Seven" when it clearly isn't!
Just watch I bet Catherhams lawyers will pounce.
In this case they are on firm ground, selling a car with one of these attached would be "passing off".
