i'm at the stage of considering what to do about brakes.
do i go for master cylinder with remote reservoir or down the servo assisted route. what do i go for in the way of pedal box.
where do i get this stuff from.
any advice and photo's much appreciated.
paul
For a light car like a Se7en you don't really "need" a servo. Then again, it takes a while getting used to a non-servo set-up if you're only used to driving "modern" cars.... It's a bit like power steering, driving a car with a servo is slightly "easier" but you lose feel....
photos of my brakes are in the photo gallery vauxhall astra (mk5) alloy rears and hi spec fronts . had to weld up the holes and redrill for the rears
but I think the results are worth it also used handbrake cables which came from Hein Gerick the motorbike shop! (2.5mm Dia Clutch cables) wil sort
part numbers for the cables if you need them (u2u me) sierra master cylinder is fine and less hassel than balencer bars a servo is not needed on light
cars like these!
look at chris gibbs book the pedel i think is like mk sportscars although I dont think they would be hard to make!
