Chris_R
| posted on 7/5/04 at 09:08 PM |
Transmission Tunnel
If you’re using a Sierra transmission is it strictly necessary to widen the tunnel to the rear of the cockpit on the drivers’ side, or is it only
required when using an Escort axel?
A bit of slapstick never hurt anyone.
http://www.chris.renney.dsl.pipex.com/
Mark Allanson
| posted on 7/5/04 at 09:12 PM |
The sierra builders will probably go into more detail in a minute, but I think the sierra diff is offset a little, they have different length
driveshafts apparently.
It is not good for a propshaft to run dead true, the needle rollers do not revolve in the case as the are designed to, and wear out the case rapidly
Chris_R
| posted on 7/5/04 at 09:21 PM |
Now you come to mention it I had noticed that the transmission wasn’t symmetrical, but didn’t know why. I was hoping to use the space to fit me in,
but it’s prolly best to leave it as is.
Cheers.
Mark Allanson
| posted on 7/5/04 at 09:27 PM |
I'm sure the sierra builders will say exactly how far it should be offset
stephen_gusterson
| posted on 7/5/04 at 10:47 PM |
I was under the understanding that diffs are not central cos the crown wheel assembly throws part of the diff to the side, and you get unequal drive
shaft lengths.
I mounted my diff centrally. (sierra type). The big advantage was that it was possible to taper the tanny tunnel to the rear and get more ass / hip
room towards the back of the seat.
The disadvantage was that I have to get one of the drive shafts modded.
The prop wont run 'true' as its slightly sloping downhill from box to diff.
It was once stated on here that diffs were offset as a vital aid to preserving the prop shaft - no one did put a reason forward for this possible
myth?
atb
steve
Mix
| posted on 8/5/04 at 09:42 AM |
The diff prop shaft flange can be mounted centrally because as Steve says it is the crownwheel offset that accounts for the different length prop
shafts. The actual mounting points are all equally spaced either side of the prop flange axis.
I've reduced the width of my tunnel to 90mm between a & b but I'm using 25mm RHS for a & b which gives an outside width of 140mm
which will:
allow the prop shaft to be fitted, (the UJs are a close fit past the k tubes but OK when installed)
allow the front mount on the diff, (120mm wide) to be attached to a & b
Using these measurements I do not have to widen the tunnel at the rear.
Cheers Mick
[Edited on 8/5/04 by Mix]
Chris_R
| posted on 8/5/04 at 09:52 AM |
Mick, cheers. That's exactly what I was hoping for. Think I'll give it a go.
