stats
| posted on 2/9/03 at 06:47 PM |
Fuel tank alternative
Has anyone used a fuel tank from a donor with any success. I saw a piccie with one from a spitfire and it looks like it could fit. Any comments
greatly appreciated
Stats
RoadkillUK
| posted on 2/9/03 at 06:49 PM |
I've heard that the spitfire tank fits in nicely (and I'm sure someone has done it). I also bid on one on ebay and lost it
I can't be sure but I think someone has mentioned the use of a Vauxhall Chevette petrol tank as a donor (not sure if it was saloon, hatchback or
estate though)
Roadkill - Lee
www.bradford7.co.uk
Latest Picture (14 Sept 2014)
chrisg
| posted on 2/9/03 at 07:51 PM |
It was Me!!
It's the saloon, don't get the one from the hatch as it's all wrong. The saloon one is between the boot and the back seat so it
comes out brand new.
Its big tho 10 gals, and nearly fills the back of my (+4) car.
I can measure it up if any one's interested.
Chris
Note to all: I really don't know when to leave well alone. I tried to get clever with the mods, then when they gave me a lifeline to see the
error of my ways, I tried to incite more trouble via u2u. So now I'm banned, never to return again. They should have done it years ago!
A Badger
| posted on 3/9/03 at 11:11 AM |
Chris,
How is your's mounted? I've got a part built +4" with a tank from a Shuvit. It's mounted vertically with the sender on the
side of the tank.
Looks a resonable installtion, though I'm a little worried about getting a fuel guage working with some reasonable accuracy.
Andrew
PS I'm in Sheffield too.
andyps
| posted on 3/9/03 at 02:58 PM |
The tank from a mini van / estate / pick up may well fit. On the mini it goes across the back behing the sub frame, under the boot floor with a filler
on the off-side. Holds six gallons. It is probably about the right size - I can get approximate dimensions if anyone wants (helped by the fact we have
a mini estate!)
I am planning to have a look at this tank with a view to fitting one.
| posted on 3/9/03 at 03:55 PM |
theres a 'mini special' fuel tank on ebay at the min for a 5er, if anyones bothered. I though that perhaps it was a bit small. Search for
fuel tank, theres not many items...
chrisg
| posted on 3/9/03 at 07:10 PM |
Andrew,
mines mounted by the same holes that are used on the Chevette on to brackets across the bottom and by two straps into the holes at the top welded to
the back rail.
My digi cams bust but I could mail you a sketch if you like.
Chris
andyps
| posted on 3/9/03 at 09:57 PM |
I doubt the mini special tank would be any use - it is probably one from the standard mini which sits inside the rear corner of the boot - the mini
van tank is much more the locost shape.
Chris Leonard
| posted on 4/9/03 at 11:43 AM |
the spitfire tank fits nicely - paid £10.00 for one
Ian Pearson
| posted on 7/9/03 at 06:52 PM |
I've used a Spitfire tank, and it fits like a glove.
Metal Hippy
| posted on 7/9/03 at 07:24 PM |
Shouldn't it fit like a fuel tank?
Cock off or cock on. You choose.
kiwirex
| posted on 9/9/03 at 08:03 AM |
Read somewhere that someone had used one out of a van.
Can't tell you where, or which van though.
Not much use today...
- Greg H
thekafer
| posted on 12/9/03 at 01:05 AM |
sand rail/dunebuggy
greatly appreciated
Stats
Checkout the spun aluminum tanks that sand rails use.They come in diameters from 6"to10" and lengths from 15" to 36".
I have'nt got that far yet, but I was going to look at these when I did.
Oh, they run $45 to$80 here.
Just a thought Fletch
bob
| posted on 12/9/03 at 06:30 AM |
MK 1 Cavalier
For the bigger tank,probably the same as the Vauxhaul chuvette.
Ian Pearson
| posted on 12/9/03 at 09:03 AM |
Can't remember the exact capacity, but it's a tad under ten gals. Can send you a couple of pics if you want?
