FEZ1025
| posted on 19/1/08 at 04:03 PM |
Tube/Pipe Bending
Anybody know of anyone in Sheffield/Rotherham/Doncaster area that can put 2x 90 degree bends in 38.1mm (1.5" tube/pipe. I have tried both
MK's & they haven't the correct former, I have a hydraulic bender but again not the correct former so all it does is kink it.
Alan...
Simon
| posted on 19/1/08 at 04:59 PM |
Alan,
As it's two separte pieces and quite thin, I'm assuming it not for a roll bar.
If so, then could you not buy some preformed bends from Milner Offroad or similar.
Simon
Triton
| posted on 19/1/08 at 05:00 PM |
Try filling with sand after first capping one end with steel plate then blanking the other end with a lump of wood or something then heat and
bend....use kids play sand though as less muck in it.
mark
FEZ1025
| posted on 19/1/08 at 05:08 PM |
quote: Originally posted by Simon
Alan,
Simon
It is actually one piece (sorry for confusion) it's like a roll bar but not, it's for the rear of a chassis. It comes from the back of the
chassis through the first 90 across the chassis & then back again, if that makes sense. Overall dimensions will end up at 13" x
33".
Alan...
Simon
| posted on 19/1/08 at 06:50 PM |
You mean the top rear most of this pic (supports the top of rear panel):
http://www.locostbuilders.co.uk/photos.php?action=showphoto&photo=10000016.jpg
If so, find a friendly plumber and use 19mm 16swg
Simon
[Edited on 19/1/08 by Simon]
rj
| posted on 19/1/08 at 06:56 PM |
You could try one of the stainless exhaust places, they all have heavy duty pipe benders with dies for various size pipe, there is one near the
Sheffield arena,another one (Top Gear ) at Scawsby Doncaster
FEZ1025
| posted on 20/1/08 at 12:48 AM |
Simon
No not really forgot you guys only think abouyt toy cars & not real ones like these,
Click here for real cars
Only joking but I'm doing some work on a new K series version, it needs to be 38.1mm with 1.50mm walls which I have already got.
quote: You could try one of the stainless exhaust places, they all have heavy duty pipe benders with dies for various size pipe, there is one near the
Yep know both those places had work done at them, will give them a ring on Monday
& see if they have a 38mm former, Thanks very much.
Alan....
wilkingj
| posted on 22/1/08 at 08:51 AM |
mark
Or Swimmingpool Filter sand. Nice and fine. Also dry and sealed in a bag. £10 for 25kgs.
Just my 2d worth
Best Regards
Geoff
http://www.v8viento.co.uk
| posted on 22/1/08 at 10:08 AM |
If you want to travel a bit there are a couple in Matlock/Darley Dale area that build 4x4 chassis and will do one offs if they have the right size die
fitted.
