speedyxjs
| posted on 20/4/08 at 08:26 PM |
What do i do now?
Pretty much finished my chassis apart from a few bits of welding but what do i do now?
Still have yet to fit the floor and make the suspension and front wishbone brackets but do i paint the chassis first?
Also, do i get the fuel tank made and get the engine running before painting?
Its been a long day i my brain cant work hard enought to work it out
Dangle_kt
| posted on 20/4/08 at 08:29 PM |
is the frame coated in anything? If not I'd paint it next, or it might rust horribly, and I wouldn't fancy grinding off rust with an
engine in place, just because it would be a pig to keep everything clean.
Whipping out a 1.5 tonne engine isn't a five minute job
| posted on 20/4/08 at 08:32 PM |
get your suspension sorted first, as brackets need welding on. I would get it built up before painting to ensure you dont forget any brackets! How are
you attaching the floor and what material?
COREdevelopments
| posted on 20/4/08 at 08:34 PM |
i would at least get the suspension brackets and engine/gearbox brackets all welded on then paint it.
rob
clairetoo
| posted on 20/4/08 at 08:50 PM |
In a perfect world I would get the car as near to finished as possible , then strip it for paint . No matter how thorough you are there will allways
be brackets and bits to add.....
Its cuz I is blond , innit
Claire xx
Will weld for food......
blakep82
| posted on 20/4/08 at 08:55 PM |
paint in oxide primer now, but don't give a final finish tll the chassis's complete and all your trial fitting of rngines and stuff is
done.
do the floor before painting primer though, if the floors being welded in
________________________
Mr Whippy
| posted on 20/4/08 at 09:05 PM |
you can buy weld through paint, works well to protect the metal and you don't have to bother removing the paint when adding a bit.
speedyxjs
| posted on 21/4/08 at 06:49 AM |
Im going to rivet ali on for the floor.
