stevio73
posted on 26/5/13 at 09:19 AM |
Wishbone tube
Hi everyone,
I've got a problem, insofar as I have run out of 35mm seamless for the wishbones. I only need five more bits 35mm long to complete the front
uppers and one rear top outer adjuster. I've done the proverbial wall of death trying to locate some to no avail as yet. Local engineering firms
have sucked their teeth and quoted for six meters worth when I reckon I'd get away with just a foot.
Does anyone have any spare? 35mm OD 29mm ID
Best I could come up with was a guy that would machine it out of solid and charge me £9 per 35mm piece. Which I thought was a bit expensive.
RichardK
| posted on 26/5/13 at 11:42 AM |
What about ebay?
eBay Item
Dunno if this link will work to the other lengths?
http://stores.ebay.co.uk/ALUMINIUM-2-BUY/35mm-OD-1-5mm-Wall-/_i.html?_fsub=2353333015&_sid=287289515&_trksid=p4634.c0.m322
Rich
[Edited on 26/5/13 by RichardK]
Gallery updated 11/01/2011
stevio73
| posted on 26/5/13 at 12:08 PM |
Ah ha, but wait...... It's only 1.5mm wall thickness!
That means it'll be 32mm ID (3mm too big for the bushes I have not to mention not strong enough)
RichardK
| posted on 26/5/13 at 12:12 PM |
He has other sizes, maybe worth a look under the precision steel tube section?
http://stores.ebay.co.uk/ALUMINIUM-2-BUY/36mm-OD-2-5mm-Wall-3mm-Wall-/_i.html?_fsub=2353334015&_sid=287289515&_trksid=p4634.c0.m322
R
RichardK
| posted on 26/5/13 at 12:14 PM |
Ah see what you mean, best of luck matey !
R
iank
| posted on 26/5/13 at 03:07 PM |
Are you sure about those dimensions?
Haynes uses 33.7mm 2.6mm thick tube according to my book (which is 28.5mm internal diameter).
Maybe try metals4u for mail order or there could be a metalsupermarket you could visit nearby.
Anonymous
Minicooper
| posted on 26/5/13 at 03:30 PM |
I used 35mm with 29mm ID seamless, I found the 33.7mm with 28.5mm ID just far too tight especially after it was powdercoated
