jabbahutt
posted on 22/11/07 at 08:10 AM |
19mm chassis bungs
Morning all
Any idea where I may be able to get some of the square chassis bungs like Tifosi sell but in 19mm instead of 25mm?
I've cut out a chassis rail for the remote gear change and would like to tidy the area rather than have an exposed hole.
either that or any other ideas to tidy up two holes that doesn't involve welding as I can't
cheers
Nigel
Paul TigerB6
| posted on 22/11/07 at 08:22 AM |
My Tiger uses what seems to be 20mm od tube so i was looking for these myself and i have found trailer retailers are the best bet.
There are some here anyway http://www.autow.co.uk/trailer_parts/plastic_inserts_prices_72.html
PS Hows the build coming along Nigel?? I'll have to pop down sometime - keep saying it to myself everytime I am down your way as my sister lives
just around the corner from you now
[Edited on 22/11/07 by Paul TigerB6]
andrew.carwithen
| posted on 22/11/07 at 09:00 AM |
B&Q sell them. Look in the section that stocks aluminium sheet, mesh, angle iron etc...
Andy.
jabbahutt
| posted on 22/11/07 at 09:20 AM |
cheers for that, off to B&Q tonight then
40inches
| posted on 24/11/07 at 11:43 AM |
You can also get them here http://stores.ebay.co.uk/Plastic-Bits_W0QQssPageNameZstrkQ3amefsQ3amesstQQtZkm
Syd Bridge
| posted on 24/11/07 at 05:23 PM |
The tubes really should be capped with welded pieces.
But, if you want to use the plastic bungs, then Hursts down in Newport have a bin full of them. 27P each. Saw them this morning, near the bolt
counter.
Syd.
