chrisf
| posted on 9/3/04 at 08:03 PM |
Suspension materials
I'm looking for advice on A-arm materials. Currently, I plan to use 3/4", .125" DOM. I plan on using heim joints for the suspension.
Rather than thread the the male heim joint into the DOM, I want to weld a 4030 threaded tube adaptor. Is this the adviseable materials to use or can I
get away with something lighter--ie thinner wall, etc?
Terrapin_racing
| posted on 10/3/04 at 12:01 PM |
Drawn Over Mandrel with tube insets should be fine. If you want to go a bit OTT you can also get them nitotec's as I did.
cheers
Rob
http://www.nitrotec.co.uk/properties/properties_frames.htm
cymtriks
| posted on 10/3/04 at 08:37 PM |
better tubes
Go up in tube diameter before increasing the wall thickness. The lower wishbone tubes are loaded in bending and the book design relies on that big 1/8
inch plate to stop it from folding up over bumps. Moving the coil pickup closer to the hub is a good thing, check out a Caterham, it gets much closer
than the book design and is less loaded as a result.
A one inch 14 gauge tube or 16 gauge tube would be stronger and lighter than the 3/4 inch 1/8 wall tube.
The 16 g tube can take 25% more load and the 14g one can take 33% more load.
Alan B
| posted on 10/3/04 at 08:55 PM |
Most of my rear suspension links are 1" 16g tube with welded in threaded bungs (1/2-20 UNF).....no bending loads on any though....seem very
strong indeed....
batfasturd
| posted on 10/3/04 at 08:58 PM |
well the kit i bought just had normal welded seam tube apparently in 16swg.
Alan B
| posted on 10/3/04 at 09:03 PM |
Nothing much wrong with ERW (welded tube) IMO.....in 20 years of usage I've never seen a failure (seam split)....I think it is pretty well made
these days
| posted on 10/3/04 at 10:18 PM |
certainly hope so! my bones are 16g 3/4 inch round ERW, plus the 3mm plate is a bit chopped about. I think this will be the first thing i replace, cos
its not very good...
Mark Allanson
| posted on 10/3/04 at 10:56 PM |
Spose 15mm copper pipe and yorkshire fittings are out of the question then?
Terrapin_racing
| posted on 11/3/04 at 09:15 AM |
I know of a failure on rear training arms on a Mallock that were 3/4" 1/16g and these had to be beefed up.
However it was pushing out over 200bhp.
Check out the Nitrotec treament I mentioned earlier. I judge at Formula Student and I see it appearing on thinner and thinner gauge tubing all the
time!
I honestly do think we are prone to over engineering - but not a bad thing for road use.
I attach an interesting article for interest
Terrapin_racing
| posted on 11/3/04 at 09:19 AM |
PS: Just saw the copper tubing post
Interestingly enough I have seen a prototype chassis made up in 15mm copper and solder fittings - beats wood mock up I suppose!
so there........
chrisf
| posted on 11/3/04 at 01:47 PM |
Thank you all for the advice. I am now clear as to what the A Arms will be made of. My current plan is to build the suspension out of the 1"
DOM. I really want to build this car so I can enjoy it next summer. When it is complete, I will start experimenting with Ti tube and the suggested
coating. That is the dream anyhow...
--Thanks all, Chris
Bob C
| posted on 11/3/04 at 01:48 PM |
We have to over-engineer, or we'll die! As amatuer builders we do one or two cars in a lifetime & there's no way we can do all the
analysis and testing Mr Ford does on his new models - it's generally a case of "if it looks right" & make it way too strong.
I'm doing an IRS for my locost. OK I can estimate static, sideways and braking forces but my biggest concern is "pothole" stress
trying to rip a wheel off, I think all I can do is make it really strong! So I'm putting 1" sq. tube down the transmission tunnel top as
well. If I'm still posting here in 3 yrs time then it must be over engineered!
cheers
Bob C
Terrapin_racing
| posted on 11/3/04 at 02:06 PM |
You'll need it over engineered with those roads around Knutsford Bob
Bob C
| posted on 11/3/04 at 04:25 PM |
ahh you've visited then.....
actually there's some nice roads hereabouts, my commute to congleton is V pleasant (not fast mind you). Too many roads ruined by gatsos &
their ilk - the cat&fiddle road has its own police helicopter on nice days!
Bob C
chrisf
| posted on 11/3/04 at 04:42 PM |
Good to hear BobC is dealing with the pot holes. I'm relying a bit on his suspension design!
I forgot to add that, after all the hard work, it looks like heim joints are not in the cards. For all the material, the cost would be about $100
USD/corner. Not locost at all. So, it looks like Delrin will win out.
[Edited on 11/3/04 by chrisf]
