New Topic New Reply
Author: Subject: Bending tube cheaply
prawnabie
posted on 5/12/09 at 08:50 PM Reply With Quote
Hi Guys
I have some 1" 1.2mm wall mild steel pipe I need to bend. Its not for anything car related or mission critical lol, just for a frame for a seat to attach to
I can cut a weld at angles I suppose but bending it would be easier - does anybody have any locost ideas.
None of the bends are more than 60 degrees
Shaun
Staple balls
posted on 5/12/09 at 08:59 PM Reply With Quote
use 22mm tube and a plumber's pipe bender?
gazza285
posted on 5/12/09 at 09:06 PM Reply With Quote
I'm afraid that the tube is so thin that without the correct formers you are going to kink it. Try hard packing it full of dry sand and heating it up first.
Gary 7
Came across this may be worth a look.
http://www.rorty-design.com/content/sand_bending.htm
Tatey
posted on 5/12/09 at 09:26 PM Reply With Quote
Do you have any electrician or plumber mates? I managed to get my mate to lend a conduit bender from work yesterday and it works a treat for bending 19mm 16swg tube.
Volvorsport
posted on 5/12/09 at 09:31 PM Reply With Quote
gas axe , without the axe bit .
www.dbsmotorsport.co.uk
getting dirty under a bus
Bluemoon
posted on 5/12/09 at 11:38 PM Reply With Quote
I do miss Rorty he used to post on here, he as some really good practical tips.
Dan
clairetoo
posted on 6/12/09 at 08:24 AM Reply With Quote
I've got a plumbers pipe bender - and a 1" former (somewhere...............)
Its cuz I is blond , innit
Claire xx
Will weld for food......
MakeEverything
posted on 6/12/09 at 08:40 AM Reply With Quote
Dan
"Sand bending is not a practicable method of bending chassis tubes"
Rorty helped me out a load when he was around as well. Very nice guy, and produced shed loads of drawings etc FOC for general consumption.
Kindest Regards,
Richard.
liam.mccaffrey
posted on 8/12/09 at 08:38 PM Reply With Quote
i have a 1" die for my Pro-tool if i can help
Build Blog
Build Photo Album
prawnabie
posted on 8/12/09 at 08:40 PM Reply With Quote
Thanks for the replies, I think I have worked out a design that will work without bends, just need to work on my fishmouths!
gazza285
posted on 8/12/09 at 08:55 PM Reply With Quote
Can't beat a bit of filing.
New Topic New Reply
