New Topic New Reply
Author: Subject: steel tube
pre lit
posted on 19/7/10 at 09:23 AM Reply With Quote
steel tube
where can i get some 35 mm od 2.5mm wall thickness seamless tube to make my own cage.who do people on here use
thanks
phelpsa
posted on 19/7/10 at 09:32 AM Reply With Quote
http://www.merlinmotorsport.co.uk/SHEETS-AND-TUBING-Roll-Cage-Tube-(CDS)/c321_329/index.html
Probably not the cheapest though. I recommed using 45mm and building to MSA specs as described here:
http://www.msauk.org/uploadedfiles/msa_forms/bluebooks/10/160-195%20Competitor%20Safety.pdf
That way should you wish to enter any events you won't have any problems...
Mal
posted on 19/7/10 at 09:40 AM Reply With Quote
Try here:
http://www.hublebas.co.uk/CFS.pdf
posted on 19/7/10 at 10:08 AM Reply With Quote
here
sells 2 and 3 mm wall.
I've bought stuff in the past from them with no probs.
phelpsa
posted on 19/7/10 at 11:32 AM Reply With Quote
1.4.1. Specifications of the tubes used:
Minimum Material
Cold Drawn Seamless Carbon Steel
Minimum Yield Strength
350 N/mm2
Minimum Dimensions (Ø in mm)
45 x 2.5 or 50 x 2.0
38 x 2.5 or 40 x 2.0 (For roll cages/bars approved
prior to 1.1.95).
1.4.2. In selecting the steel, attention must be paid to
obtaining good elongation properties and adequate
weldability.
1.4.3. The tubing must be bent by a cold working
process and the centreline bend radius must be at
least three times the tube diameter. If the tubing is
ovalised during bending, the ratio of minor to major
diameter must be 0.9 or greater.
Unless there's a specific reason for you to use 35mm?
pre lit
posted on 26/7/10 at 11:33 AM Reply With Quote
my rear bar is 35mm and im going to build the cage using the existing bar
New Topic New Reply
