RoadkillUK
| posted on 26/8/02 at 10:53 PM |
Steering column bracket
Would this bracket pass the SVA, I made it today but as you can see I've not welded it or drilled it yet but looking at it later, I'm wondering if
it will or not.
The 3/4 piece of square near the brakes is just holding the column in position until welded etc. It's the 'L' shaped piece I'm worried about.
Roadkill - Lee
www.bradford7.co.uk
Latest Picture (14 Sept 2014)
mad-butcher
| posted on 27/8/02 at 05:15 PM |
not to sure myself about the crossbrace that you're clamped to it all depends on knee clearance in event of a shunt. take a look at MK indy chassis
and put a hoop in seams easier.
regards
tony
interestedparty
| posted on 27/8/02 at 06:04 PM |
I think the handle of the G clamp will need careful radiusing
John
| posted on 28/8/02 at 07:28 AM |
One suggestion - clamp it as well as you are able, then sit in the car (on a plank!) and try and wiggle the wheel vigorously from side to side.
Obviously don't compromise your collapsable column!
This is the sort of thing the SVA tester might well do, and if he detects any movement he might reject it.
The reason I say this is that the bracket looks like it may twist a bit - but it looks quite thick so you should be OK.
