TimC
| posted on 20/3/11 at 10:24 PM |
Drawing of bias-brake footwell bulkhead?
Does anyone have a drawing of a bulkhead panel to take twin standard girling-type master cylinders as seen in the right hand side of the pic below?
Cheers!
Richard Quinn
| posted on 21/3/11 at 09:34 AM |
Does it not depend whose pedal box you are going to use as there could be a bit of variation in the spacing? Just choose whose box you will use and
then contact them to see if they have a drawing of the back panel of the box for you.
TimC
| posted on 21/3/11 at 12:46 PM |
It's a very fair point you make - the pedals are from Matt @ Procomp, but the original bulkhead went welded with the chassis. The balance bar
is the usual kit-car fodder (my MNR had the same one) and I think the OBP one is virtually the same, so I think (!) it's relatively standard or
at least will still work fine even if it differs by a mm or three.
I could ask Matt but I know he's up to his eyes and what he produces for his cars probably won't be large enough for my giant footwell on
the Gemini.
stevegough
| posted on 21/3/11 at 07:36 PM |
If you are at the design stage of the footwell - be careful how much room there is - I have an OBP pedal box, I also have moderate size 8 feet - now -
I can drive it ok with my 'slip - ons' , but with either of my two pairs of trainers on, my clutch foot catches the brake pedal ! Most of
my big-footed buddies can't drive it!
Luego Locost C20XE.
IVA passed Jan 28th 2011.
First drive Feb 10th 2011.
First PASA mad drive 26/7/11
TimC
| posted on 21/3/11 at 07:58 PM |
Don't worry - the footwell on the Gemini is massive and I'll be wearing NOMEX race boots! I'm probably going to move the pedals
back too - in order to shift my short-arse 13-14st self backwards which makes the space even bigger again.
Thanks for your input though.
[Edited on 21/3/11 by TimC]
Doctor Derek Doctors
| posted on 25/3/11 at 02:03 PM |
OI! Were did you get that picture of my car?
Richard Quinn
| posted on 25/3/11 at 03:32 PM |
You got a Gemini too?
| posted on 25/3/11 at 05:30 PM |
Nope thats my car.... The Life-Taker
I think Tim will get the joke.
TimC
| posted on 25/3/11 at 06:25 PM |
I get it. Do you want to buy some matching pedals?
