locoboy
| posted on 12/8/04 at 01:29 PM |
Top Chassis Rail
This is one for all you technical strucural type peeps out there.
I have a Triton Built book chassis and one of the styling elements i like on the indy (and my F27) is that the top chassis rail where you would rest
your elbow if you were not haning on to the wheel for grim death, is lower at the back than at the front where the scuttle is mounted.
now what i need to know is,
Can i cut mine and lower the rear end of it a bit.
If so do i need to have the chassis in a prety much no external stress position so as not to bend / upset any other chassis tubes when i cut this one
through?
And lastly will doing this give me any casue for concern with loss of strength issues etc?
Many thanks
Col
Locoboy
white130d
| posted on 12/8/04 at 01:42 PM |
Yep
Col, I lowered mine to met the top of the M2 tube instead of being approx 1.5" above it. It does also affect the curved piece that surronds the
rear wing.
I think this looks a little better than level, but the elbow is gettin closer to the scrape zone.
"There's only 2 things that money can't buy, and that's true love and home grown tomatos" Guy Clark
James
| posted on 12/8/04 at 02:04 PM |
David?
Guess you have an understanding partner- you seem to be building in the dining room!
James
white130d
| posted on 12/8/04 at 02:26 PM |
Seems like it
James, as much time as I spend down hre you would think so, but that is actually the "dirty" area of my shop...in the background you see a
small lounge area complete with a fridge, where I sit and ponder the next step (maybe even drink a beer if it's after hours).
David.
mangogrooveworkshop
| posted on 12/8/04 at 08:47 PM |
The history lesson for to day is
The original design had this slope in round tube This shows the differances between them all including the turbo DSK with 180 brake!!!! that was a
long time back! Rotary was also the fashion and broken tubes!
picked this up of the web sometime ago
leto
| posted on 13/8/04 at 08:01 AM |
My very personal thoughts:
Cut it out completely and refit, don't cut rear end and bend it down.
one through?
Have the chassis extremely well clamped down to something VERY rigid and cross measure before, and after each step.
There will be some loss of strength and some increase in loads but no real cause for concern if you move it just “a bit” and the welds are
reasonable.
Cheers!
“I'm gonna ride around in style
I'm gonna drive everybody wild
'Cause I'll have the only one there is a round”. (J. Cash)
andyharding
| posted on 13/8/04 at 08:14 AM |
Just a note:
The MK chassis has the front upper rails 1" higher rather than the rear lower. This is to accomadate larger engines.
Now if only I'd thought of that before I started my chassis my Zetec might actually fit in...
stephen_gusterson
| posted on 13/8/04 at 08:50 AM |
my rail, to create the doors, is 4 inches lower......
in order to get stiffeness back, i made the tranny tunnel structural. Under the doors I doubled up with rhs, so its basically a rectangle of 1 x 2
tubes under the doors. then I welded a plate over the whole rectangle. Then, by the drivers legs section, I added X braces rather than the normal /
style, and weleded another triangular gusset in there. At the back of the doors, I added 2 diagonals bracing into the rear bulkhead.
After 2 years as a built up rolling chassis, its dimensionally stable and hopefully will be on the road!
atb steve
garage19
| posted on 13/8/04 at 09:22 AM |
David.
Cool. What do you sell?
Just a small thought. Are you sure you can get your chassis out of the room after it is finished!???
[Edited on 13/8/04 by garage19]
timf
| posted on 13/8/04 at 09:28 AM |
doug its and americanism
shop short for workshop
white130d
| posted on 14/8/04 at 11:40 PM |
Actually
I have a small independent Land Rover shop doing parts and service...and at the other end of this part of the building is a 10' X 10'
sliding door so if I can get it of the table I can get it out of the building. I did once build a boat in the basement....that took a little effort
to get out.
