New Topic New Reply
Author: Subject: Round tube?
Macca
posted on 12/9/02 at 09:07 PM Reply With Quote
Round tube?
Is there any good reason that would stop me from producing a chassis in round tube. I except that it will take longer, but would it be as strong. Would I be able to use the same size of steel, ie 1" round instead of box etc.
Cheers Col.
bob
posted on 12/9/02 at 09:30 PM Reply With Quote
i'm sure it would make panels harder to fit not having a flat edge to rivet/fix too.
Jasper
posted on 12/9/02 at 09:37 PM Reply With Quote
Sure it would be harder to fit them all together too, trying to cut all the angles...
Rob Allison
posted on 12/9/02 at 09:44 PM Reply With Quote
I can say from my experience of building a robin hood 2b that riveting to round tube is not easy. check out lolocost.co.uk there chassis is round tube.
Rob..
Wadders
posted on 12/9/02 at 10:18 PM Reply With Quote
whats the reason for wanting to use round tube macca?
To produce accurate joints you will need to
be very acomplished with the angle grinder, as theoretically each joint needs to be templated to achieve a snug fit,in practice on tube as small as 1" dia most engineers would use the trial and error method,which unless youv'e had a lot of experience,error would be the norm. If you then end up with big gaps to fill,welding will be much harder, my advice to you is,unless the round tube is free, stick to square.
Sorry
Al
Macca
posted on 12/9/02 at 10:43 PM Reply With Quote
Point taken, bloody stupid idea anyway if you ask me!!!!!!!!!!!!!!
Cheers Col.
MrFluffy
posted on 13/9/02 at 09:16 AM Reply With Quote
Why not use square for all the chassis, and then use round for the bits you can see like the cage etc? That way you only have the pain in the bum stuff to work with for the pretty bits.
Dunc
1" round tube wouldn't be as strong as square but would be lighter for same wall thickness. A larger OD would've been beneficial to thicker wall thickness.
jcduroc
posted on 13/9/02 at 04:49 PM Reply With Quote
Dunc is absolutely right.
However has anyone calculated the necessary modulus of all the tubes of a chassis? I mean, wouldn't many of the bay triangulation tubes be sufficiently strong if round 1" (or even 3/4" in some cases)?
Questionable issue, I guess.
Joćo
cymtriks
posted on 13/9/02 at 07:43 PM Reply With Quote
In theory a properly designed spaceframe relies on its triangulation and not on the beam properties of its tubes for its overall torsional and bending properties. At a more local level the need to resist bending forces caused by supporting masses such as the engine and gearbox and to provide resistance against buckling under normal loads requires minimum beam section properties. Other factors such as weight saving, ease of welding and resistance to minor damage also play a part. A 1 inch square or round tube in 16 gauge provides a good compromise. Using 1 inch round tube gives a weight saving of about 22% over 1 inch square but cutting all the joints properly will be very tricky. You will also lose 22% of the torsional stiffness which takes you down from about 1200 to 1400 ftlbs per degree for the book car to about 900 to 1100. This isn't enough as the book chassis is only adequate as standard. In my earlier postings I outline how to double the torsional stiffness, reduce the weight and use less tubes than in the book chassis. These mods could be used for a 3/4 inch square 16 gauge tube and 20 gauge (1mm) sheet steel chassis which would still beat the book chassis with around 1800 ftlbs per degree of twist and give about a 30% weight saving. I wouldn't recommend such a light car structure for an engine much heavier than a bike engine though.
New Topic New Reply
