Lars
| posted on 14/9/02 at 03:19 PM |
2 quick questions
1. in the book it says to use a 16swg steel sheet for the floor, but would 1mm be enough?
2. will i have to make any modifications to the transmission tunnel to fit a t9 gearbox?
stephen_gusterson
| posted on 14/9/02 at 05:12 PM |
quote: 1. in the book it says to use a 16swg steel sheet for the floor, but would 1mm be enough?
1. probably
2. probably not.
short answers?
basically, the floor just stops your bum hitting the ground and stops things hitting you. its not structural. i would recommend that you put an extra
one or two rhs members across the car under where you bolt the seat or the floor will move around and 'ping' a lot.
Alu is about 1/3 weight of steel. why not use alu if you are trying to save weight on the floor?
the tranny tunnel is relatively wide in the book, compaed to the prop shaft dia. However i made my car 6 is wider so my impression of room may not be
the same as yours. You are most likely to have to increase the width of the opening at the bellhousing end of the aperture. however, you might
compromise, if you have room, by moving the engine forward. on my car it was the clutch release arm that was a pain.
atb
steve
theconrodkid
| posted on 15/9/02 at 06:57 AM |
I built book chassis and fitted a type 9 no probs
Mark Allanson
| posted on 15/9/02 at 09:02 PM |
In the book its says you should use 16g for the floor or use the roof panel from the (Escort Mk2) donor. The roof on the essy is only 20g (0.9mm) so I
dont suppose it matters?
Lars
| posted on 16/9/02 at 07:42 PM |
that's what i was wondering, because all the roofs i've seen so far seemed to be about 1mm, so i thought that the old escort may have had a thicker
roof.
interestedparty
| posted on 16/9/02 at 07:54 PM |
I expect that in the book 16swg was suggested because it is easily obtainable, not because it is the minimum thickness suitable
John
RoadkillUK
| posted on 16/9/02 at 08:15 PM |
I have got 2 sheets of 16swg steel and I don't think I'll be using it, it's way too thick in my opinion, I'm sure I can make use of it on some
other project.
Roadkill - Lee
www.bradford7.co.uk
Latest Picture (14 Sept 2014)
david walker
| posted on 16/9/02 at 08:26 PM |
I used 20swg sheet steel. It's OK but I had to fit a couple of additional cross members afterwards as when you stepped into the car the floor wobbled
and distorted. OK now. For weight reasons I wouldn't have used 16swg.
Dave Walker, Race Engine Services - 07957 454659 or 01636 671277
stephen_gusterson
| posted on 16/9/02 at 08:38 PM |
quote: I used 20swg sheet steel. It's OK but I had to fit a couple of additional cross members afterwards as when you stepped into the car the floor
wobbled and distorted. OK now. For weight reasons I wouldn't have used 16swg.
you found the same as i did. I used 16 swg and you still get the wobble.
Use a couple of extra supports for the seat and the floor can be virtually anything. However, there was a nasty report on TOL once of an aussie
getting something sharp up through an alu floor once. Dont suppose there are too many spiky things on english roads thou.
atb
steve
Highcost builder
| posted on 16/9/02 at 08:56 PM |
the crossflow box and t9 box have the same size bell housing just swapped them over this weekend and they fitted fine with the exception of the base
rail by the starting motor got a bit closer there than before.
