unijacko67
| posted on 28/11/12 at 07:44 PM |
Nyloc nuts
Can anyone help me identify what size nuts I need to source and where from.
They are on my alfa axle diff housing and used to have a tab washer, but I’m gonna replace with nyloc.
The axle has normal metric threads on some parts, so I believe these will be metric fine?
Spanner size 14mm, bolt outside diameter is just under 8mm, nut inside is 7mm. Are they 8mm metric fine or what?
http://www.kittenkitcar.co.uk
r1_pete
| posted on 28/11/12 at 07:54 PM |
Possibly metric fine, just under 8mm, could be 5/16 unf.
Best thing to do is invest in a thread gauge Clarke Quality Thread Pitch Gauge Internal External Screw Mertic 60 degree
| posted on 28/11/12 at 07:57 PM |
Get a Zuess chart as well as the thread gauges to help identify threads
unijacko67
| posted on 28/11/12 at 08:18 PM |
What a dummy I am, your reply's jogged my memory about my 30 year old tap and die set, just wire brushed all the rust of a tap that fitts and
it's 8 x 1.0 , now to order some.
Cheers for help.
| posted on 28/11/12 at 09:23 PM |
I would expect they should just be standard M8x1.25 just try a standard M8 nut on with your fingers,
If the thread looks very fine they could be M8x1 or much less likely on an Italian car 5/16" UNF.
unijacko67
| posted on 28/11/12 at 10:18 PM |
Thanks, I’ve sorted it now. Metric fine, 8 x 1.0
