Big T
| posted on 17/3/22 at 10:54 PM |
SSC Conversion Questions.
Hello All,
I have got a bit confused, doesn't take a lot to be fair, with some of the instructions in the conversion guide from Saturn. Concerningly its
the first real change from the book chassis. I am pretty sure i have got this figured, however just wanted a little bit of clarification really.
The confusion is within the "RS" section of the guide, to quote the guide it says...
Construct RS1,2,3 as manual. Cut RS4 to RS9 as the amended lengths. RS10 remain the same. Assemble
RS4 to RS9 in the same format as instructed in the manual. The external separation between RS4 and RS5
is amended to 752mm from 627mm
Now when i go to the details in the back of the guide, the only amendments to the cut size appear to be RS6 RS8 & RS9 despite the paragraph quoted
above. In addition to that, when i look at the detailed drawing with at the highlighted sections that are amended the sections RS4 to RS9 are amended,
however i am taking a wild guess that this is because these parts are moved outwards from the centreline of the chassis but are not amended.
Am I right in thinking that RS4, RS5, RS7 & RS7a are cut at book dimensions and just spaced out with the only amendments being to RS6, RS8 &
RS9?
I am fairly confident that logic is right and the quoted paragraph is a typo, but the i dont really want to be cutting a load of my chassis our
because I've misread something.
Thanks for any help in advance.
Slimy38
| posted on 18/3/22 at 08:57 AM |
I would strongly recommend you treat the Saturn plans as only a guide, not as a proper instruction manual. I think you're right, even though
they say RS4 to RS9 they are only referring to the three that actually change.
I found it's best to try and understand what they're aiming for, then double check the measurements against what you have. Definitely
don't pre-cut the steel, just do each individual piece (or pair of pieces) as you go.
You're still very early on in the document by the looks of it, you're about to find some of the other measurements are also not quite
right (or even completely missing!!). It does work eventually, but it is a bit of a step up from the step-by-step instructions in the Haynes manual.
