jbmcsorley
| posted on 29/3/02 at 01:37 AM |
tire-to-chassis clearance?
I'm finally at a point where I can choose a width for my chassis (based on my donor axle) and I want to be sure there is enough
clearance between the inside of my tires (47.5") and my current chassis plans (book +4 = 46"). That leaves only 3/4" clearance and it seems a
little too close for comfort.
What's an appropriate clearance between the chassis and the inside edge of the wheel/tire for a live axle design?
TIA,
-Jim M.
stephen_gusterson
| posted on 29/3/02 at 11:37 AM |
Hope you get a good answer from bit this and the other list you posted on Jim.
As was said on 'tother list, if using book suspension, the swing arms are gonna be the thing to look out for that come frm chassis to axle.
ChrisW
| posted on 29/3/02 at 12:27 PM |
I've noticed the same problem using a mk2 Escort axle. Can't remember who told me but apparently it'll all go together fine. If not, it
shouldn't be too much hassle to use wheel spacers and long wheel bolts to increase the track width a little.
Chris
My gaff my rules
chrisg
posted on 29/3/02 at 07:06 PM |
Hi Jim,
I think you'll b be fine with that, mines about the same and there's only 20 mm between my starter and the frame1
Chris
jbmcsorley
| posted on 29/4/02 at 09:57 PM |
Cheers Chris,
I recently found rose/heim joint brackets that are about 30mm wide instead of the book's 50mm. By using heim joints on the chassis side of the
linkage I have a full 50mm clearance for the tires.
Ciao,
-Jim M.
