caber
| posted on 1/10/05 at 07:15 PM |
Build started . . . .
Well I got the electroysis tank running today and got the cortina uprights in bits and in the tank. It would help if I knew what I was building! I am
aiming to build a book chassis with a beam rear axel however I do not have a donor yet so depending on what I can find it may be IRS.
If I go IRS I will be looking at a wider chassis so the first thing I am going to build are the front wishbones!
I will have to do some practice welding to get the quality and speed up, I tried a bit of scrap today and although the welds look good there was poor
penetration possibly because I have got in the habit of using large rods as these work well for repair work, I am talking about gas welding by the
way. First set of technical questions will be posted on the running gear section!
Caber
gary gsx
| posted on 1/10/05 at 07:47 PM |
Is it ok to gas weld the chassis??? didnt think you could do it on car repairs for m.o.t,s dont quote me i may be wrong
| posted on 1/10/05 at 07:51 PM |
You are You can gas weld the chassis, and you can gas weld cars to repair damage. Only downside with gas is that it puts a lot of heat into the
joint so there is a higher risk of distortion.
Hornet
| posted on 3/10/05 at 12:29 PM |
hi.. The confusion is.... you can weld with gas for MOT.. but you cannot "Braze".
Cheers J
