jon_haggerty
| posted on 13/10/05 at 01:56 PM |
chassis plans
asically i want to build a locost as per book but with IRS using sierra parts. Are there any downloadable chassis plans out there and where?
James
| posted on 13/10/05 at 02:02 PM |
Please do a search on this- it's been asked and answered a few times before.
James
- Muhammad Ali
jon_haggerty
posted on 13/10/05 at 02:11 PM |
Sorry
James
| posted on 13/10/05 at 02:18 PM |
You've made me feel guilty now!
Basically, there aren't really any plans.
A few people have come up with their own designs (Mix, and a few others) and then a lot (including several manufacturers I won't mention) just
rip off MK's design.
Best advice to you is to use the DeDion system (with Sierra diff' ) from MK or GTS Tuning (see links above!) and bolt it to a standard book
chassis. GTS supply plans to adapt the normal chassis to use their De Dion system.
It's what I'd have used if it'd been available when I started.
Hope that helps,
James
[Edited on 13/10/05 by James]
- Muhammad Ali
jon_haggerty
| posted on 13/10/05 at 02:21 PM |
I did try and look at the gts site but as you say its a de dion system. I was thinking just wishbones at the back and a sierra lsd diff in the niddle.
And stick it all together on the back of a book chassis. Any ideas who does that? Sorry again, Jon
James
| posted on 13/10/05 at 02:25 PM |
IRS is only really a bonus if you've got it setup exactly right and know how to tune it.
The DeDion is an excellent compromise between IRS and Live Axle.
At the end of the day there are plenty of really excellent Locosts with Live Axle. As Steve Gusterson once said "I've never heard anyone
say: My standard Locost doesn't handle well"!
Go DeDion and your life will be a lot simpler- I've done IRS so I should know!
James
- Muhammad Ali
Russ-Turner
| posted on 13/10/05 at 02:57 PM |
Came across this the other day.
http://www.georgecushing.net/SierraIRS.html
caber
| posted on 13/10/05 at 03:05 PM |
There is a book in the SpeedPro Series called "How to build your own Tiger Avon Sports Car" by Jim Dudley ISBN 1-903706-09-2. This has
full drawings and build info for a sierra based 7 with double wishbone rear suspension. The main chassis is similar to the Locost though there is a
bit more bracing on the sides, and different bracing arrangements elsewhere, probably a bit heavier but useful for ideas to mod the locostif you
don't want to build this version.
Regards
Caber
Bob C
| posted on 13/10/05 at 03:06 PM |
A few of us have gone for a different donor for IRS, I used mx5 uprights which are available for reasonable cost. But I still used sierra diff.
Downside with mx5 uprights is that the front track rod attatchment is all a bit unfortunate, but the back end is just the job.
Bob C
mark chandler
| posted on 13/10/05 at 03:40 PM |
I,m using this one as a guide
" target="_blank">http://locost7.info/files/chassis/Chassis_Sierra.pdf
Gav
| posted on 13/10/05 at 03:45 PM |
I started the same way, i evan bought the tiger book, however since its my first build i thought id go for a tried and tested method with the DeDion
from GTS if i feel the need later i can easily adapt the chassis to use IRS now i understand how the chassis is put together.
jon_haggerty
| posted on 13/10/05 at 05:14 PM |
Cheers everyone. Like i say, i wanted to go the complete IRS route from the beginning even though this is my first build and im too stuck in my ways
to change now. Thanks for all your input and patience.
Avoneer
| posted on 13/10/05 at 05:29 PM |
Regards
Caber
Yeah, but the geometrey is all wrong and from the seats back, there is no adequate triangulation.
Pat...
jon_haggerty
| posted on 13/10/05 at 09:54 PM |
Has anyone tried the mcSorley method? I think thats what im going to try. Any pro's and con's?
kb58
| posted on 13/10/05 at 10:55 PM |
quote: Originally posted by James
As Steve Gusterson once said "I've never heard anyone say: My standard Locost doesn't handle well"!
Even ignoring cornering, the smooth ride of IRS over real-world bumpy roads will make that same Locost much more pleasent to live with.
[Edited on 10/14/05 by kb58]
And its book -
http://www.lulu.com/shop/kurt-bilinski/kimini-how-to-design-and-build-a-mid-engine-sports-car-from-scratch/paperback/product-4858803.html
