joolsmi16
| posted on 29/1/06 at 07:38 PM |
w/bones, hubs
Hi all, whats involved in changed my "book" suspension setup with cortina uprights/hubs to sierra ones?.
Can anyone post front wishbone dimension and the "U" bracket positions for the sierra hubs??
I am trying to find some wide track wishbones for the book locost but can only find wide track for sierra setup!
Triton
| posted on 29/1/06 at 08:18 PM |
Mk do that mod i think....best ask them.
www.tritonraceseats.com
www.hairyhedgehog.com
Avoneer
| posted on 29/1/06 at 08:43 PM |
So will you be using Cortina or Sierra uprights?
Bit confused...
Either way, MK, MNR or MK Engineering should be able to help.
Pat...
jon_boy
| posted on 29/1/06 at 10:28 PM |
Is it that different? i thought that the changes could be adjusted for by screwing in some ends etc??!1
Avoneer
| posted on 29/1/06 at 10:51 PM |
Nope - new top bone required due to the difference in alignment of the top ball joint on each upright.
Pat...
jon_boy
| posted on 29/1/06 at 11:50 PM |
ooh booger!!
scotmac
| posted on 31/1/06 at 05:16 PM |
Difference in alignment fore-aft, or side-to-side? And if side-to-side, can't you simply get some type of extension (i know it has been done on
steering track-ends)?
[Edited on 31/1/06 by scotmac]
scotmac
| posted on 31/1/06 at 05:17 PM |
Oh, right, cortina to sierra, instead of the usual vice-a-versa. So, you would need to cut the top wishbone down a bit, if possible???
