iscmatt
posted on 14/5/06 at 09:27 PM |
Help with Rivetting Please!
When rivetting the chassis to attach the floor panel should I drill right through the chassis frame or just through the bottom 'skin' if
you catch my drift
indykid
| posted on 14/5/06 at 09:39 PM |
jut the bottom of the tube!
and sikaflex between floor and tubes too.
hth
tom
schnelle bak
| posted on 14/5/06 at 09:41 PM |
just drill through the first layer off the chassis, so the 2 mm ali plate and the 1,5 mm from the chassis, that's all
kb58
| posted on 14/5/06 at 09:50 PM |
Yikes... yes, what they said. You drill through two surfaces total. One is the sheet you are attaching to the car, and the second is the bottom
surface of the square tubes on the floor. Do NOT continue to drill all the way through. It is neither needed nor necessary.
And its book -
http://www.lulu.com/shop/kurt-bilinski/kimini-how-to-design-and-build-a-mid-engine-sports-car-from-scratch/paperback/product-4858803.html
iscmatt
| posted on 14/5/06 at 09:56 PM |
Most helpful. Many thanx to you all
indykid
| posted on 14/5/06 at 09:57 PM |
quite welcome
tom
Kissy
| posted on 15/5/06 at 06:33 AM |
Be worth buying some skin grips to help you (small temporary clamps that pick up on rivet holes, used in the a/c and m/sport industry. That way you
can take the panel off after drilling and de-burr all holes (except the inside of the tube!!). For the floor you'll need approx 5, the more the
better.
Kissy
| posted on 15/5/06 at 06:37 AM |
Like this:
http://www.prifast.co.uk/clamp.htm
donut
| posted on 15/5/06 at 07:05 AM |
Make sure you turn the chassis upside down before you start, makes life alot easier!!
