robertst
| posted on 11/6/06 at 01:08 PM |
mcsorley plans
yesterday i was preparing the cutting list for the chassis in order to know how much to buy, but after doublec-hecking the measurements, the +4chassis
plans do not include the measurements for the transmission tunnel. is this because they are the same as the book chassis? anyway, i couldnt find
measurements for the tunnel. the book has to have them right?
Tom
Gav
| posted on 11/6/06 at 01:18 PM |
When i did mine i just used the length from the rear bulkhead to the first horizontal tube then x4 + 4meters or so so i would have a bit of extra tube
in stock if i needed it for other things.
DIY Si
| posted on 11/6/06 at 01:51 PM |
Always buy at least 4-6 metres more than you think you'll need. Chances are you'll cut a tube or two a little short, mess something up,
decide to add a tube here and there etc etc. I started off building a +4, but then decided to add loads of extra triangulation. This added at least
another 8-10 metres overall.
robertst
| posted on 11/6/06 at 05:55 PM |
ok, thanks.
i just dont wanna mess up the height of the transmission tunnel, or the triangulation.
Tom
Gav
| posted on 11/6/06 at 07:46 PM |
yeah use the book for the trans tunnel dimensions, although you might want to adapt it for what ever engine your using.
Mark Allanson
| posted on 11/6/06 at 07:50 PM |
Simple tip, don't let your tranny tunnel uprights coincide with the wide bit at the back end of your type 9 (if you are using one)
Don't ask me how I know this
