jlparsons
| posted on 4/7/06 at 06:56 PM |
Anyone built the "Rorty" IRS?
THis link:
http://gtslocost.locostsites.co.uk/documents/pdf_files/RortyLocostIRSAssembly.pdf
Takes you to a pdf file describing this IRS design. Just wondering if anyone has built it (or close enough) or has any feedback on the design?
Site seems well worth a look.
Cheers folks!
Any resemblance to real persons, living or dead is purely coincidental. Some assembly required. Batteries not included. Contents may settle during
shipment. Use only as directed. No other warranty expressed or implied. Do not use while operating a motor vehicle or heavy equipment. Subject to
approval, terms and conditions apply. Apply only to affected area. For recreational use only. All models over 18 years of age. No user-serviceable
parts inside. Subject to change. As seen on TV. One size fits all. May contain nuts. Slippery when wet. For office use only. Edited for television.
Keep cool; process promptly.
meany
| posted on 4/7/06 at 07:36 PM |
in the process at the moment.
adapted to fit the McSorley 442 chassis.
although i havent got to the wishbones or hubcarriers as of yet.
not even done my diff mounts.
andyps
| posted on 4/7/06 at 10:13 PM |
Someone did say that the design is based around book width, rather than Sierra components, but I haven't measured things to verify this. It is
currently my plan to go this way, unless I buy in the rear suspension components complete.
locostv8
| posted on 4/7/06 at 11:13 PM |
Deman uses Ford 8.8 bits, I am not sure I like their execution but the idea is good and in a LC it would be unbreakable.
http://www.deman-motorsport.com/build.htm
I'm not sure of your location or the availability of these parts there. I'm doing a +4 length +4 or 6 width and +2 or 3 height. My build
is a bit over the top with Ford 351W and 315 35 17 rear with a 7" backset and with these in mind the standard width Tbird Supercoupe or Lincoln
MK VIII IRS fits well I believe I can use Rorty plans widened down the middle. I will be using a few Cobra and Explorer parts to increase the size of
the stubs and half shaft diameter. I can provide a bit more info if anyone cares.
[Edited on 5/7/06 by locostv8]
http://wrangler.rutgers.edu/gallery2/v/7slotgrille/hssss/
