welshboy
| posted on 10/2/07 at 03:10 PM |
seat belt mountings
hi im building a book chassis and fitting 4 point belts the book shows you welding a triangle bit of 3mm plate on the inside of the trailing arm
bracket. is there still going to be room for my seat belt mounting ? do you use the same hole as the trailing arm ? a pick would help if any on could
show me there bottom seat belt mountings thanks
DIY Si
| posted on 10/2/07 at 03:29 PM |
Some people just use the same bolt for both.
Sun Tzu, The Art of War
welshboy
| posted on 10/2/07 at 04:23 PM |
and is it ok si for the sva thanks
DIY Si
| posted on 10/2/07 at 06:25 PM |
As long as it's a big/strong enough bolt, then yup. Something in a 10.9 or 12.9 should do fine if you're not sure.
