speedyxjs
| posted on 11/3/07 at 08:49 PM |
Longer Chassis
Im thinking about starting my chassis in a few weeks and im a bit concerned my jag aj6 might not fit .
I was thinking about extening the engine bay (chassis rails F1, F2 and G1, G2 in the old book and BR1, 2, 8 and 9 in the new book) but keeping the
front the same width.
Will i run into problems with strength or anything if i do this or has anyone else got any suggestions/advice. (using a different engine is NOT an
option )
907
| posted on 11/3/07 at 09:00 PM |
Hi
Draw out the book chassis on the build board.
Sit your engine/gearbox on the board.
Change to suit. That's what I did.
Paul G
Ivan
| posted on 11/3/07 at 09:09 PM |
That's going to be a difficult one to answer - firstly a lot depends on how far back you can set the engine (normally limited by bell housing
width) so the wider the car the better. Also using a 6 weight distribution becomes a factor so you want the motor far back.
If you can get the motor far enough back then you shouldn't need to lengthen the engine bay - with my 4AGe motor theres more than enough room
for 2 more cylinders in front of the motor.
I think if you lengthen the bay G1 & G2 are the weak links and will need strengthening/supporting to carry the motor - also you should duplicate
member R on the other side
Have a look at papers published by Cymtrix on here at simple mods that significantly strengthen the chassis.
James
| posted on 12/3/07 at 09:05 AM |
If you just lengthen those tubes then your suspension mounts will change position... not necessarily a good idea!
If you don't know what you're doing with suspension design I'd be careful with this... you don't want to trash the handling
after all!
HTH,
James
- Muhammad Ali
Volvorsport
| posted on 12/3/07 at 12:47 PM |
have you got any measurements for the engine and box ?
the volvo 6 cylinder fits in my chassis - it does come quite far foward tho , so i can measure it and see what we come up with .
www.dbsmotorsport.co.uk
getting dirty under a bus
speedyxjs
| posted on 12/3/07 at 02:24 PM |
Have you got any pics?
907
| posted on 12/3/07 at 05:54 PM |
Is the g/box a Getrag?
Paul G
speedyxjs
| posted on 12/3/07 at 08:25 PM |
Paul G
Yes it is .
The measurements of the engine are 34 Inch by 23 inch roughly
907
| posted on 12/3/07 at 09:13 PM |
Mmmm, That's a big lump.
I have a Getrag on a lotus engine.
My chassis is +4 wide. My foot wells are book so the extra 4" is in the g/box space.
By doing this the front end of the bell housing is level with the end of the foot well.
This leaves 35 1/2" ish to the front of the engine bay.
I can see now why you would want to make yours bigger.
If you don't follow this I'll take a photo.
Paul G
speedyxjs
| posted on 12/3/07 at 09:16 PM |
I do follow but any pics would be great. Nothing beats visual aids    .
Mark Allanson
| posted on 12/3/07 at 09:26 PM |
I would make the upper and lower rails of 50x25mm 16g ERW and make the H tubes 50mm shorter. A small weight increase, but a massive sag resistance
added to the chassis - needed with a big tubby engine
907
| posted on 12/3/07 at 09:46 PM |
I like Mark's idea.
Perhaps bolt in triangulation after fitting the engine???
Pic below shows added 4" although I did it just to move the engine back for weight reasons.
Paul G
Volvorsport
| posted on 12/3/07 at 11:05 PM |
sundays trip to santa pod .
should be some pics of use
http://forums.turbobricks.com/showthread.php?t=94099
andyps
| posted on 12/3/07 at 11:44 PM |
quote: Originally posted by speedyxjs
(using a different engine is NOT an option )
Course it is an option - you should make it wider too and fit the Jag V12 in
| posted on 13/3/07 at 11:02 AM |
My main concern would be weight, much as I love Jag 6s the AJ6 engine was a heavy bit of kit.
For starters I would think 4inch wider 4inch longer + 1 (or 2) inch deeper + Cymitrics mods.
| posted on 13/3/07 at 11:05 AM |
Might be better to keep the H tubes book length, the extra depth will make the chassis stiffer in beam bending and give more room in the footwells.
| posted on 13/3/07 at 11:09 AM |
But real Jags have XK engines :-)
speedyxjs
| posted on 13/3/07 at 12:45 PM |
2.9 aj6 is only for SVA. She will then be upgraded to 4.0 aj16 and SUPERCHARGED
