New Topic New Reply
Author: Subject: Bolt stress grades
Taz Surfleet
posted on 30/3/07 at 10:37 AM Reply With Quote
Bolt stress grades
Hi Chaps
have just taken bought some of Nick Skidmore's (cheers Nick) rose joints in 3/8 unf does any one have a stress grade charts for imperial all the ones i can find are in metric !
Mr Whippy
posted on 30/3/07 at 10:49 AM Reply With Quote
a die hard imperialist
t.j.
posted on 30/3/07 at 11:04 AM Reply With Quote
What is imperial??
In Dutch it is a roof-rack
http://www.skf.com/portal/skf/home/products?paf_dm=shared&maincatalogue=1&lang=en&newlink=3_3_11
maybe this: http://euler9.tripod.com/bolt-database/22.html
[Edited on 30/3/07 by t.j.]
Mr Whippy
posted on 30/3/07 at 11:26 AM Reply With Quote
Imperial was what we were before we gave it all away and became a nothing on the polical ladder...Bring back the Empire!
Mal
posted on 30/3/07 at 11:45 AM Reply With Quote
UNF strength grades.
I'm not fully up to speed on this, but there appear to be 2 systems for giving this information.
UNF bolts used on British cars of the 60's and 70's were stamped with either: R, S, T, or X. These being inceasing values of either yeild or UTS figures in tons/ square inch. I think R was 45/55, S 50/60 and T 55/65 from memory.
There is another, more current system which uses different numbers of radial lines stamped on the head.
This site here gives more detail.
www.rockcrawler.com/techreports/fasteners/index.asp
HTH
Mal
Nick Skidmore
posted on 30/3/07 at 03:21 PM Reply With Quote
I have the best grade Aerospace NAS bolts available from stock for not much more than commercial stuff.
The info I'll need from you will be the diameter which I guess is 3/8 and the distance between the outer edges of the bracket you are bolting through.
These are 95.000 psi in shear and 160,000 psi in tension without the brittleness of industrial 12.9 grade stuff.
[Edited on 30/3/07 by Nick Skidmore]
Confused but excited.
posted on 30/3/07 at 07:43 PM Reply With Quote
Originally posted by t.j.
What is imperial?
A natural, God given, system of measurement.
Back off Brussels!
Macbeast
posted on 30/3/07 at 08:22 PM Reply With Quote
Imperial is the Dutch attitude to Indonesia
t.j.
posted on 30/3/07 at 09:20 PM Reply With Quote
You Dutch-India
We don't want them back. First let us clean up the mess in Europe.
But I still think you should get that EURO-coin! And drive on the right side of the road
posted on 30/3/07 at 09:32 PM Reply With Quote
The left is the right side of the road
gazza285
posted on 30/3/07 at 09:51 PM Reply With Quote
I already drive on the right side of the car, you want me to drive on the wrong side of the road as well?
Taz Surfleet
posted on 30/3/07 at 09:56 PM Reply With Quote
Wish I'd known when I bought the joints Nick! will measure the brackets tomorrow and send u2u.
JB
Senior Builder
Posts 436
Registered 20/5/04
Member Is Offline
Photo Archive Go!
Building: Built: V8 Kitten, 2 litre Lada, Space frame Minor,
posted on 31/3/07 at 04:40 AM Reply With Quote
Bolts
Aerospace bolts are the way to go for suspension etc. You know they are high quality, are plated and available in the correct length without having to cut a load of thread off.
New Topic New Reply
