| posted on 30/7/07 at 08:52 PM |
Welding Up Rivet Holes!
Right...
Chassis stripped for shot-blast and powdercoat, but... I've got a squillion and one rivet holes that I don't want full of sand.
Welding them up is easy enough, but what would you recommend for smoothing down the weld so that the chassis rails are nice and flat again?
clockwork
| posted on 30/7/07 at 08:55 PM |
Angle grinder + file + "grease de elbow"
"Those who would give up Essential Liberty to purchase a little Temporary Safety, deserve neither Liberty nor Safety." Benjamin Franklin.
"Well if you have nothing to hide, you have nothing to fear" Morons the world over.
Locost/Kit builders info and FAQ website:- www.carbuilders.info
907
| posted on 30/7/07 at 09:04 PM |
Flap disc.
Paul G
| posted on 30/7/07 at 09:18 PM |
I got some 80 grit fibre disks and use them with a flexible nylon backing pad in my grinder. They last for ages and polish the metal instead of
digging in like grinding wheels.
RazMan
| posted on 30/7/07 at 09:32 PM |
The angle grinder flap wheels are ideal for that job
Raz
NigeEss
| posted on 30/7/07 at 10:10 PM |
I use flapdisks too, these ones Flappylink in fact.
Brilliant.
Litemoth
| posted on 31/7/07 at 05:35 AM |
I'm with Pete,
Grinding disks are a bit severe for this job as you don't want to thin the walls of the tube. I've found the fibre discs (with the nylon
backing pad) most successful for this. Guard manufacturers and sheet metal fabricators use these for finishing welds.
If you're feeling lucky; There are these funky see-through grindy disks available now - they allow you to see what you're wrecking as it
happens!
See Screwfix
[Edited on 31/7/07 by Litemoth]
clockwork
| posted on 2/8/07 at 02:25 PM |
I've not had a problem with my angle grinder, maybe I'm careful, but out of curiosity went and got the fibredisks to give them a try.
Have to say I was impressed.
I've learnt something new today
| posted on 3/8/07 at 11:05 AM |
I've always known the flexible discs as 'linishing' discs. They are essential if you are welding external panels on car bodywork
etc. where the weld needs to be invisible afterwards.
| posted on 3/8/07 at 12:13 PM |
I bought mine
here and got a nylon backing pad for about £4 from a local diy shop. They should last for years.
