carcentric
| posted on 1/10/03 at 06:02 PM |
Tubes R and Z
Is there a reason why there are no tubes to mirror R and Z?
Seems a breach in symmetry, unless it's to create a collision "crumple zone" or something.
M D "Doc" Nugent
http://www.carcentric.com
| posted on 1/10/03 at 07:03 PM |
i think r gets in the way of certain engines, and z may be just to reinforce the side where the panard rod goes. triangulation and the like!
Mark Allanson
| posted on 1/10/03 at 07:07 PM |
I have 2 Z's, and after this weekend, will have 2 R's. The lack of the O/S Z is baffling, the N/S R is due to crossflow dangly bits, my
pinto does not have the same problem, so i am going to fit one.
stephen_gusterson
| posted on 1/10/03 at 10:18 PM |
I thought it was either cos it hits the manifold, or is a throwback to the original lotus design where minimalist design was the thing.
atb
steve
Tigers
| posted on 3/10/03 at 11:15 AM |
Question on tubes TR1,2,3,4
Hi!
Does anybody have a clue why tubes TR1 are round ones, not RHS? Maybe just beacuse they ar lighter, or what?
Thanks in advance,
Janis
ned
| posted on 3/10/03 at 11:34 AM |
I've done mine in sq. tube, many others i've seen have to. Probably was what uncle ron had available when building the original car!
Ned.
beware, I've got yellow skin
Tigers
| posted on 3/10/03 at 11:46 AM |
Just as I thougt.
Then I also wouldn't be messing with round tubes.
Thanks!
Janis
James
| posted on 3/10/03 at 03:11 PM |
quote: Originally posted by Tigers
Just as I thougt.
Thanks!
Janis
Bear in mind using square TR tubes in the engine bay may have some bearing on how you do the engine bay bodywork as you won't be able to
'curve' the ali round square tubes.
HTH,
James
[Edited on 3/10/03 by James]
