chrsgrain
| posted on 11/4/08 at 04:15 PM |
cleaning steel before welding
Hi all,
Got some ERW tube to weld together, and its coated in some anti rust stuff - how clean does it need to be to weld, and how is best to clean it?? Also,
same questions but for painting...
Chris
zilspeed
| posted on 11/4/08 at 04:18 PM |
The answer as always.....
Grinder with wire brush.
Rust / coating / paint gone in 60 nanoseconds.
Next ?
Stuart_B
| posted on 11/4/08 at 04:52 PM |
Next ?
Seconded
stuart
caber
| posted on 11/4/08 at 05:17 PM |
Flap wheel on angry grinder equally good!
Caber
tks
| posted on 11/4/08 at 06:17 PM |
Caber
yupsz..
anychit that will be there will be burned anyway...
Tks
MikeR
| posted on 11/4/08 at 06:22 PM |
and if thats too noisy then file / wire brush / emery (sp?) paper combinations till the steel goes bright.
907
| posted on 11/4/08 at 07:02 PM |
quote: Originally posted by chrsgrain
Hi all,
If the anti rust stuff is a type of grease then wipe this off first with a paraffin or panel wipe soaked rag,
then a flap disc on the weld area only.
You will have to degrease prior to painting so you might as well do this sooner than later.
At least you will then be working with clean material.
Paul G
