I'm almost ready for welding my alu fuel tank. It should fit in a MK Indy R with full roll cage.
Can someone help me with some dimensions for the tank or some pictures ? Thanks !
This is what mine looks like. It's from MK but yours might be slightly different as my rollbar isn't standard.
Thanks for the picture ! How will the tank be attached to the chassis ?
Tigerseal apparently. Mk reckon you don't need straps anymore. I've used tigerseal before and it is extremly strong so i can't see a problem.
MK Fuel Tank dimensions
This is the 'normal' tank, as mentioned it's stuck to the chassis rails with PU adhesive.
