Finally got my Indy out for a run (on a private bit of land) at work.
What a feeling after 2 years plus seems all worth while. Went like stink and I never got over 8k revs! Managed a cheeky run up the road so got it up
to 5th.
Many thanks to all on here who have answered stupid questions and in general for the great knowledgebase this place is.
Few little niggles, a small oil leak and complete lack of self centering. Diff clunks a bit when taking up slack and nearly knocked the bloody exhaust
off on the trailer!!! Three helpers and still buggered it up so some fettling there as bent the bracket.
IVA application next, just need to check emissions and cover all those pesky sharp edges.
Woohoo!
Videos
Rich
[Edited on 20/3/11 by rb968]
looks more like an industrial estate but never mind ;o)
well done
You may find the diff always clunks on a BEC !!!
was that you mate radioing the fuzz at the end of the vid
Ssshhhh ;-)
That'll be my firms idea of security........designed to put of scumbags tear arsing around in cars on the car park !
What air Box are you running. Saw it fly by in the video.
Its a home made effort . Used the 1.2mm Ali I had left over. cheapo cone filter.
Made it to fit onto the pipercross baseplate that was there but was very noisy. For IVA purposes decided to change it. Seems to run well with it
fitted. Not much science behind it, hopefuly just common sense! Folded and rivetted by hand, bit of araldite.
Airbox
Rich
Nice, really nice. I have been looking around for a while. Have not reach the point of building one yet, but yours looks pretty good.
Haha....a coat of satin black covers a multitude of sins!
I may well switch back to a new pipercross later but at least have the option of this if a track days needs a low noise level.
If i can knock one up I am sure you can. Basically a base plate with slots cut out and bent to slot into he pipercross base plate. Side pieces bent
and rivetted on and a top piece with the edges bent over and rivetted. I araldited right angle pieces internally so I could rivet through. Plenty of
sealant and a coat of paint.
Rich
