Morning all,
Wondered if anyone has Russbost's photon twin projector headlights on their Indy? Want to see what they look like before I buy some. Also, how
did you bolt them on to the standard Indy R chassis mounting bracket?
Am also open to alternative headlight suggestions. Want something smaller than the standard 7" ones.
mads
[Edited on 5/7/12 by mads]
These are mine, 4" satin black headlights...
just bolted straight on!
As above, 4" Dominator's in chrome,bolt straight on.
Not sure if those are IVA-able, but I'd def go with this type rather than the twin type of Russ'
Don't get me wrong he's a great bloke, it's just a preferential/aesthetic thing...
Part's of these car's need to look lairy (decals for instance) and parts need to look "of an age", in my humble opinion...
I think Russ also sells the Dominator headlights.
Don't know if this is an Indy, but will give the general idea (it's a LSIS, they all look the same to me!!!
Tw proj on 7 off
Tw proj on 7 close up
Tw proj on 7 on
I do of course sell the single dominators should you prefer them, got some great new single projectors just come in doing dip & main within the
Photon single alloy body
^^^ yup that's an Indy Russ
Mads it is my Indy in the pics above there are more in my archive (RB folder).
I can take more pics for you if you need them.
The 4" Dominators have been known to fail IVA, not because of the flat beam paternal, but because the flat line was not defined enough. It was
put down to the cheap chinese build quality IIRC.
It should be said that many do pass IVA though.
[Edited on 5/7/12 by loggyboy]
Thanks YQUSTA. Have looked at pics in your archive. I think the mounting bracket for the headlamps has changed from the Indy to Indy R as mine just has a single hole for the headlamp to bolt through vertically - dont really want to be changing that either.
