What hand brake cable do I need to fit to my Indy using the standard rear drum setup?
I am at the same point and am led to believe standard sierra but have look in the photo archive at cairb i contacted colin to see if he had a photo
of the cable route as it is an absolute b######d
regards tony
I'm sure i've heard of people using fiesta handbrake cable on the indy,i'm going too shorten the sierra one clamping the wire together in the tunnel area.
Once you have cut and shortened the handbrake cable what is the best way to re join it?
Paul
I'm joining mine with clamps as used on trailers,I will be trying to source these clamps next week so i'll let you know.
bob you can get them little clamps out of focus diy... they are a bit fiddly cos theve got small nuts
or if you wanna laugh you could do it
the robinhood way
b
i got the ones from focus DIY but they are very different,the trailer ones are 2 pieces of steel with U shape ground out back to back and clamped
together.
When I made a Robin Hood, I shortened a std sierra cable by cutting one end off and reforming the nipple rather than cutting it in the middle.
yeah thats what im doing. reforming nipples...
am gunna squash it real good and mig it a bit just in case
I drilled a hole down the centre of the unthreaded bit of a bolt then threaded it onto the cut end of the cable and then clouted it really hard with a
sledge hammer!
Can't remember if I tried to tie a knot - probably a bit stiff for that - but its still working 7 years later. I didn't have a welder but best advice
then was to chase the exposed cable end back to make a blob.
NB: Cut the cable with a welder or solder the cable where you're going to cut it and use decent snips or the strands will fray and never go back
together. This will allow you to unthread and rethread the cable from the outer.
[Edited on 10/11/02 by geoff shep]
i was given(stole) a special tool for cutting bowden cable,looks just like the ones you use for cutting small(10mmish)
branches on trees n bushes,work just fine.
Cant reform the nipple ends on mine as i've got discs at rear,its a sort of hook/eyelet piece so i'll have to clamp it in tunnel.
Nipple, stiff, exposed end! - all we need to say now is moist and .... uh oh.
PS: Is that allowed?
Get friendly with an AA patrolman, they have alternative nipples (am I allowed to say that!!!) for almost every cable you can think of.
The nipples have grub screw conversions so they can fix a busted cable on the roadside. I think they are on bonus if they get a member mobile (am I
