Probably a daft question, but which way up does it go?
Judging from the pre-drilled holes in it, it appears to go with the cup on the end facing down.
Is that correct?
Stu
My lighting bar was welded on by MK and the cups are underneath.
Steve.
I put it on with cups up. I know what you mean the holes are made in different sizes for bolting it on. For SVA i'm not sure actually. I just ended up widening the holes to take M8 bolts into rivnuts.
