what do i need to be checking for mk indy sva fail points please
side panel edges,
Steve.
self centering
looking at your avatar, will your Grille pass on radiused edge?
when I went with my aluminium "pulled apart" type grille in MAC1 Mark zip tied three lengths of wiring conduit on the front of it so that
the examiner can't (in theory) get his test dome in there.
apart from that, I'm afraid I don't know any other shortcomings of the indy, so hth
cheers,
Steve.
I've just measured up the harness mounting points to the specified point on my seats and it seems that I may need to loose 20mm or so, so of with
the runners I think! Anyone else found this?
also
what about sharp edges under the dash such as where the scuttle sticks out from the top rail into the car.
HTH
john.
