Oh well, as per usualy with my build. Its a case of highs and lows. Usually highs of buying bargain bits, then the lows of stuffing up putting them
on.
This time, whilst cutting the scuttle to fit over the steel bar behind the dashboard I cut the side of the suttle. I was using a hole saw to get a
nice neat hole. Unfortunatly I didn't expect a nice neat 3mm or so in the side too.
Another ham fisted moment with a drill to go with the obligatory rogue rivnut living somewhere in my chassis.
Oh well I guess I'll have to work out some design to paint on the area when I have filled 'n' sanded it.
Does'nt the indicator go there?
Or a reinforced wing mirror mounting plate?
We have all done it or similar, at least you hand was not in the path of said drill.
Well after reading this lot and slinging down a bottle of Tribute I'm feeling better about it all know.
I guess I'll just have to work out which pokemon to paint on the side for the nipper.
