hi, what size are the bolts required for the harness??
If this did not make sense here is a picture.
sorry about the size.
Stuart
7/16 unf 8.8 min with the spec stamped on the head
Normally 7/16UNF. Some harnesses (Sabelts) use 8mm HT 12.9 bolts instead.
... but 99% 7/16 UNF as ^^^^^^^^
Thank you, i wil see if i can get some if they do not come with the harness.
Stuart
they will most likely come with three lines one the top this is the equivalent of 8.8
the threads are 7/16ths on the mk chassis
if you have trouble getting them,the seat belt bolts from your sierra donor car fit the threads and are 8.8 ton.
I got some Willians harneses that only come with the top eye bolts.
I got some 7/16 bolts for the bottom from Tifosi today for £1.50 each. Give them a buzz 01769 581 454
where are Tifosi located?
Devon, me thinks
Bit far for me.
