been reading through some old posts, but i just want to make extra sure before a start drilling holes etc, should the scuttlle line up flush with the
bar running across? as show in the photo?
Do you have MK's Battery Tray Piece?
I think the best way to line up the scuttle is with the change in direction on the side panel once it is fitted.
Steven.
I gaffer taped the nose cone and bonnet on to make sure it all fitted properly
Turned out to be a good move as it was a bugger to get it all lined up properly.
Deffo work back from the nosecone/bonnet and have the side panels temporarily fitted in place
I did mine this way as well![]()
So did we. Third vote here.![]()
Phil
