The handset can be blacklisted so that no one can use it. Each handset has a unique serial number.
If you dial * # 0 6 # a 15 digit number will appear on the screen. Write it down and keep it in a safe place.
If your phone is stolen or lost, phone your service provider and give them this code.
They will be able to block your handset so that the phone will be useless, even if the Sim card is changed.
You probably won't get your phone back, but whoever stole it can't use/sell it either.
If everybody did this, there would be no point in stealing mobile phones.
The number is called the IMEI number, and can usually also be found on the original box that the phone was in.
I had to phone up my service provider and do this when my last phone got nicked. Its no hassle to them. And as said, it renders the handset useless,
as the networks will not recognise it anymore, even if the sim is changed.
Well that's the theory anyway, but in practice the IMEI number can also be changed with all the correct equipment as found on your local market
stall. This is illegal of course but then stealing your phone is also.
Dave
If you're in the UK and you tell your UK provider that your phone has been stolen it will be blacklisted but the blacklisting will only take
effect on UK networks, so you could export the phone and it will still work on any non-UK network. The other thing you can do, as mentioned above is
to reflash the IMEI, supposedly impossible but easy enough to do.
If you look on ebay you'll find that there are quite a few blacklisted phones and they sell for close to the price they'd fetch if they
weren't blacklisted, that means that its cheap and easy to make them usable again.
it getting better at least, they only used to blacklist it on the network you used it on, nowadays its all uk ones. Flashing imei should be a more serious offense, there no legitimate reason for doing it is there?
imei numbers can not be changed on most phones now(anything in the last year), also if your caught doing it and there are people out there checking it comes with 5 years behind bars, we dont do that sort of thing now, i doubt you'll find a shop willing to change an imei.
