-matt
| posted on 7/10/10 at 09:53 AM |
diff fitting?
im trying to fit my diff, but seem to have a problem.
the MK brackets are 7" top and bottom.
but my diff is 7.5" at the top and 7" at the bottom.
is the diff supposed to be like this? or will i need a different diff?
cheers
-matt
| posted on 7/10/10 at 10:06 AM |
just had a look in here: http://www.locostbuilders.co.uk/forum/3/viewthread.php?tid=143758
and it looks like ive got the 7.5" diff.
so looks like ill have to have a look out for a 7"
norm007
| posted on 7/10/10 at 11:23 AM |
Where abouts are you?
Which ratio are you looking for?
I have a 3.62 if your interested?
Something about this, so very wrong.....I have to laugh out loud, I wish I didn`t like this!!!!!!!!!!!!!!
-matt
| posted on 7/10/10 at 11:39 AM |
yes its a 3:62 (bolt on) im after.
im 217 miles from yorkshire, so its a bit far to go. but will keep you in mind if i can't find one soon.
midge
| posted on 7/10/10 at 11:45 AM |
I had the same problem. I cut off the top left hand fixing on the chassis (all of the other fixing points match up), fitted the diff and made a new
bracket for the remaining fixing. Also had to grind a bit off of the diff 'fins' to get it in.
hth Steve
dilley
| posted on 7/10/10 at 12:33 PM |
I'm from Suffolk but traveling to yorkshire tomorrow if that helps?
INDY BIRD
| posted on 8/10/10 at 05:00 PM |
i also have a reconditioned 7" 362 diff if needed like new,
based in essex if any help???
-matt
| posted on 8/10/10 at 06:03 PM |
cheers lads for the offers, but ive gone for this, seems as its a LSD
3:62 LSD
