ed_crouch
| posted on 5/2/06 at 03:07 PM |
Pinto into Indy: how??
Hello everybody.
Are the engine mounting holes pre-drilled in the indy chassis, or is it a case of craning one's Pinto into the bay and measuring between the
gearbox output flange and diff flange and drilling holes in the right place etc..???
Ta.
Ed.
P.S. If i have to drill the holes myself, presumably I want the engine as far back as it will go??
I-iii-iii-iii-ts ME!
Hurrah.
www.wings-and-wheels.net
tom windmill
| posted on 5/2/06 at 03:15 PM |
hi,
i have a pinto in my indy and you have to drill the foles your self although there is only realy 1 place it can go you cant move it that much but i
have just got mine as far back as it will go
HTH Tom
ed_crouch
| posted on 5/2/06 at 03:17 PM |
Tom,
OK. Thanks.
Ed.
Hurrah.
MkIndy7
| posted on 5/2/06 at 05:20 PM |
Sounds like it depends on when you bought your kit, ours is about 2 years old and I'm sure it had the holes pre- drilled
jacko
| posted on 5/2/06 at 06:54 PM |
Hi my chassis was pre drilled
Jacko
indykid
| posted on 5/2/06 at 07:04 PM |
as was mine.
i picked my chassis up on 31st jan 2004 fwiw. the holes are just in the middle of the plates.
you have to drill your own gearbox mount holes though.
hth
tom
[Edited on 5/2/06 by indykid]
jacko
| posted on 5/2/06 at 07:20 PM |
Hi was your chassis for a bike engine ?i dont think thay are drilled when you get them new from mk
Jacko
whitestu
| posted on 5/2/06 at 08:32 PM |
Bought mine in Nov 05 - engine mounting holes were drilled [noth that thay fit my engine]. Gearbox ones were not.
stu
donut
| posted on 5/2/06 at 09:05 PM |
Mine were not drilled so go with 1st suggestion
ditchlewis
| posted on 6/2/06 at 08:50 AM |
the holes in my chassis were pre drilled for the engine, but the gear box were not.
ditch
Jonte
| posted on 6/2/06 at 09:31 PM |
Mine was delivered february 2004 and had the engine mounts hole drilled, but not for the gearbox
Click it
